Clutch fan is loud. I think????????
Hey guys i took the stank out to prance and when i returned i noticed that when you stand at the front of the car you can hear a wierd sound ( like a humming that is pretty loud. I think it is the clutch fan. Not sure. How can i check
RE: Clutch fan is loud. I think????????
Sounds like ur talking about the powersteering pump, which is totally normal. Pop the hood and listen to the ps pump for the noise?
If you have an aluminumflex fan like me (not electric) it tends to be pretty noisy cutting through the air. Until i put under drive pulleys on, whichslowed down the water pump pulley, it was extremely noisy.
if it were a clutch fan it'd be really loud..like a whirlwind...most likely Power steering pump wine is what you here....check fluid level and or adjust accordingly
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
