probs after charger install
#21
RE: probs after charger install
I'm not saying it's the problem, but it's worth a try. You have a lot more air rushing in the cylinders now, it could easily be blowing out the spark. I had that problem even when I was running 9 psi. Closed the gap, problem solved. Also, if you experience detonation, run 1 or 2 step colder plugs.
#22
does this car have a MAF or the older MAP sensor system?? I have seen problems with the older map systems if you have a map on your car call your local ford dealer and get the maf conversion. if not check your fuel filter the increased demand for fuel on a partially clogged filter will do the same
09-10-2015 08:39 PM
