How to get the steering column out?!?!?
Old 04-17-2008, 05:32 PM
ryan_89_mustang
ryan_89_mustang's Avatar
Default How to get the steering column out?!?!?
I have the column dropped all connections off and I have the bolt by the firewall out but it seems to be seized together there is not enough room to hit it with a hammer I could just barely get the wd40 on it. It does not want to slide out at all I pulled with all I had but am afraid of hurting the rack and I really don't want to do that. Does anyone have any good suggestions please I am so close to getting this car on the road.
Thanks, any input would be appreciated.
ryan_89_mustang is offline
Old 04-17-2008, 06:12 PM
5.0 MPG
5.0 MPG's Avatar
Default RE: How to get the steering column out?!?!?
did youdisconnect the knuckle fromyour rack under your hood?
5.0 MPG is offline
Old 04-17-2008, 06:34 PM
ryan_89_mustang
ORIGINAL: 5.0 MPG
I have everything disconnected but I cannot get the shaft to slide out from the column shaft. theres a shaft inserted into a shaft right by the firewall right before the first U-joint. I Am looking for suggestions to unseize these shafts they are rusted together I think.
Old 04-17-2008, 08:48 PM
93 LX FiveO
93 LX FiveO's Avatar
unbolt the rack and slide it out
i never took mine out but once unbolted from the rack, it moved pretty freely.
93 LX FiveO is offline
Old 04-18-2008, 12:43 AM
ryan_89_mustang
ORIGINAL: 93 LX FiveO
I can't unbolt it from the rack because I have to fit it through the boot in the firewall. I have all the nessesary bolts off but the two shafts up higher are stuck together really good. Does anyone have a solution to get these apart?
Old 04-18-2008, 03:38 AM
ponyboy302
ponyboy302's Avatar
mine was tight also .. you just have to get that wd40 in there and let it sit .. if you use the lil red straw with the wd 40 you should be able to angle it so you can spray the shaft .. thats the only way unless you unbolt the knuckle .. it also helps to have one person in the car and one in the engine bay ....and if you decide to unbolt the knuckle it should slide through the boot is only rubber ..
ponyboy302 is offline
Old 04-18-2008, 05:11 AM
ryan_89_mustang
damn, I lost my little red straw i got as close as I could I'm going to see how it is today. Does anyone know if ill hurt something buy pulling extremely hard on the wheel like any joints or the steering rack?
lincolnshibuya
12-08-2020 01:49 PM
CS2007
06-25-2019 09:45 PM
ChampInSD
10-02-2015 04:55 AM
allenmaty
09-24-2015 09:17 AM
stark777
09-21-2015 12:46 PM
Quick Reply: How to get the steering column out?!?!?
