little orange in antifreeze
i noticed orange in my antifreeze but could it be my radiator because it looks pretty rusted inside? also what does antifreeze look like with a blown head gasket? and i noticed like a slice in my blockkind of like a crack a little below my valve cover hopefuly its not but what will i notice with a cracked block?
RE: little orange in antifreeze
Did you put the current antifreeze in the motor?
It is possible that someone put the Orange type in your motor, which would be bad...
Regardless, do a cooling system flush and add some new GREEN coolant...
A cracked block would dump coolant... assuming the crack was common to a cooling passage...
stangin1996gt
09-21-2015 11:01 AM
09-08-2015 11:50 AM
