New to the Fox body world and need some info
I just bought a 88 GT AOD and it needs a little work......As most do. Anyway, the car runs pretty strong for the age but there are a few problems. First, the car seems to load up when driving around town, almost like a two-stroke. I just rev it a few times and it clears out. There is no smoke coming out the pipes either. I just put new plugs, wires, cap and all that stuff on today with no change. The car has the stock headers with some cheap mufflers so it seems to not be breathing well. I was wondering what would cause the car to build up like that. Could it be that I need a new coil or something?
Second, the transmission shifts like it should when getting to speed but when I slow down and drive around town it seems to stay in third.
If any of you all have any ideas it would be appreciated..... Thanks.
RE: New to the Fox body world and need some info
i would look for vac not being attached/ broken going to the fuel pressure regulator. if you pull the vac line off...it bumps to a constant 42 psi instead of regulating between 36-42
does the tranny bog down ? or just doesn't wanna downshift. believe it or not...thats probably normal on an aod, i remember both of mine not ds'ing very well
ORIGINAL: mjr46
glad to hear you fixed it
my timing was off a air line when i did my cam and intake job..it was only off a hair line and made the car feel like it didnt even want to move..fixed the timing and it was perfect every since
01-21-2016 01:30 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
