Need help for 347 stroker??????????
Old 04-23-2008, 06:44 AM
jeep81
jeep81's Avatar
Default Need help for 347 stroker??????????
Hi
I am new in this forum, and I have budget around 1000$ for stroker kit. the car is daily driver and steer/drag.
Which kit do u advice me to buy?I am looking for 400-450 rwhp.I haveBBK LT headers with flowmaster 40 series, stock trans AOD, ram air, flowtech intake. Will the trans handle the power for few months?
Thx
jeep81 is offline
Old 04-23-2008, 08:17 AM
Mustangkiler
Mustangkiler's Avatar
Default RE: Need help for 347 stroker??????????
That kind of horsepower, id get a trans cooler and valve bodybut other than thatyou should be finethe only stroker kits i found for that price are cast iron crank hyper pistons and i beam rods, any of thsoe are like 899 or 999.
Mustangkiler is offline
Old 04-23-2008, 09:04 AM
Jrichber95GTS
Jrichber95GTS's Avatar
I just dont see that much power for that little money.
Jrichber95GTS is offline
Old 04-23-2008, 10:41 AM
crvtkilla
crvtkilla's Avatar
i dont know how good the quality is but coast high performance sells a probe347 kit with a cast stell crank, 4340 forged i beam rods and forged probe pistons. i think they had a deal for like 950. im not sure about their cranks and rods but i know probe has a pretty good reputation for pistons. but your going to need one heck of a top end to put 400 or 450 to the ground. at the crank wouldnt be to hard but to get that much at the wheels will be tough. but you could do it. it will just be expensive.
crvtkilla is offline
Old 04-23-2008, 10:53 AM
5_0Muscle
5_0Muscle's Avatar
I got mine from ADPerformance with forged pistons, forged I-beams, and a cast crank for about $950. But $1000 will not be nearly enough. You have to factor in balancing, machine work on the block, gaskets. Then there is reliablity to think of such as new oil pump, new harmonic balancer, new flywheel (depending on the balancing weight you choose). So $1000 will buy you a kit but you won't be able to use it without more money.
Just some things to think about.
5_0Muscle is offline
Old 04-23-2008, 10:56 AM
5_0Muscle
5_0Muscle's Avatar
Also I doubt you'll get 400hp unless you get a nice cam maybe custom which will set you back another $500. Then some aluminium heads. Sorry to bring you down. but these are things that I learned when I did mine. I had a budget of $5000 (which included suspension also) and I still went over.
Old 04-23-2008, 12:03 PM
crvtkilla
crvtkilla's Avatar
yea i just kind of assumed that he just meant 1000 for just the stroker kit. it will cost you a good couple thousand for top end pieces and machine work and supporting mods.
Old 04-23-2008, 12:52 PM
Joel5.0
Joel5.0's Avatar
If it's the stroker kit you're looking for, check these alternatives .... LMK
Joel5.0 is offline
Old 04-23-2008, 01:00 PM
crvtkilla
crvtkilla's Avatar
wow thats a good link joel. i wish i would have known that before buying one form coast high. i bought the steet fighter kit but i was like 100 dollars more than the link you listed.
Old 04-23-2008, 05:56 PM
jeep81
jeep81's Avatar
ORIGINAL: Joel5.0
Yes this whatI meant. The budget is only for stroker not include head els..
jeep81 is offline
Quick Reply: Need help for 347 stroker??????????
