problem
problem
Okay last night I took off my air silencer. I disconnected my battery to reset my computer. Then I took the car for probably a 6 mile drive. Now when I go to put my car in park, it idles weird for about 5 seconds. My car almost dies. Does anyone know why this is happening? Did I maybe not drive my car long enough to reset my computer?
Please help.
Thankyou.
Please help.
Thankyou.
RE: problem
is it best to reset the computer after mods like this because i recently bypassed my smog pump n i never disconnected the battery cable it is at the shop right now getting a new tranny will they reset the computer for me? to adjust to my new tranny?
RE: problem
you should "reset" the computer after doing any mods to the engine. by disconnecting the negative battery cable for 15 minutes, this clears the KAM (keep alive memory) in the computer for the readings it was used to seeing from all the various engine sensors and it will learn the new readings once you have driven the car normally for a while.
RE: problem
The computer will recalculate the proper parameters once you floor it at WOT. Driving it 5 miles or 50 miles won't make a difference.
My car does the same thing. When it is cold and I have driven it hard (late for work kind of driving) and when I press in the clutch it drops to 500rpms and back to 800-900 for normal idle. Only does this when I drive hard when cold. Shows that you should always warm up your car.
I also need an oil change really bad and have taken my silencer off too. But to let you know my car did that before the silencer was taken off. Think it is a bad battery or fuel pump showing signs of dying.
stangin1996gt
09-21-2015 11:01 AM
