intake gasket
can you tell me what intake gasket fit on tfs twisted wedge... i buy stock gasket and the port is to small... thanks
RE: intake gasket
I have TFS heads and upper and lower intake.. Nice setup!
Try this... http://www.trickflow.com/egnsearch.a...115+4294908282 If not I know felpro makes them.... BUT MAKE SURE U CHECK THE WATER PASSAGES ON THE LOWER INTAKE TO THE HEADS SOME GASKETS NEED TRIMMING OVER THE WATER PASSAGE.. MINE DID. NO LEAKS.. AND ALSO DO NOT USE CORK ON THE REAR PART OF THE LOWER INTAKE EITHER, USE RTV, THE CORK SITS TOO HIGH |
RE: intake gasket
just get with summit or who ever you are buying the gaskets from and ask them for the felpro gasket that is designed for your intake manifold. felpro makes gaskets for popular models of intakes. at least they made gaskets to fit the manifolds i have installed.
RE: intake gasket
I like the Fel Pro 1250, use it on my AFR's. You do need to trim the water pasage though.
RE: intake gasket
do you think the feel-pro 1250 port 1.20x2.00 will not block my head port (TFS TWISTED WEDGE) ???
RE: intake gasket
It's bigger than AFR 165 ports are. They make bigger port sizes than that if you need it, but I imagine the TW ports can't be that huge. Check their site, it should say what size/part # gasket works.
RE: intake gasket
I have high ports with 1250's, then they work fine, and the ports on my heads are bigger than yours
