problem
Old 04-20-2005, 10:55 PM
FastFox
FastFox's Avatar
Default problem
Okay last night I took off my air silencer. I disconnected my battery to reset my computer. Then I took the car for probably a 6 mile drive. Now when I go to put my car in park, it idles weird for about 5 seconds. My car almost dies. Does anyone know why this is happening? Did I maybe not drive my car long enough to reset my computer?
Please help.
Thankyou.
FastFox is offline
Old 04-20-2005, 11:01 PM
fordguy17
fordguy17's Avatar
Default RE: problem
for how long did you disconnect the battery. i think its supposed to be about 20 minutes. then you need to drive for 25-50 miles.
fordguy17 is offline
Old 04-20-2005, 11:07 PM
FastFox
FastFox's Avatar
Default RE: problem
yeah I had it disconnected for probably an hour, because I cleaned up everything really well.
I will try driving it for that long and see what the results are.
thanks
FastFox is offline
Old 04-21-2005, 12:08 AM
stanglx2002
stanglx2002's Avatar
Default RE: problem
start the car and let it run for about 5 minutes not touching it at all and let the computer read everything
stanglx2002 is offline
Old 04-21-2005, 12:46 AM
BlackGT5.0
BlackGT5.0's Avatar
Default RE: problem
is it best to reset the computer after mods like this because i recently bypassed my smog pump n i never disconnected the battery cable it is at the shop right now getting a new tranny will they reset the computer for me? to adjust to my new tranny?
BlackGT5.0 is offline
Old 04-21-2005, 01:56 PM
roundman
roundman's Avatar
Default RE: problem
you should "reset" the computer after doing any mods to the engine. by disconnecting the negative battery cable for 15 minutes, this clears the KAM (keep alive memory) in the computer for the readings it was used to seeing from all the various engine sensors and it will learn the new readings once you have driven the car normally for a while.
roundman is offline
Old 04-21-2005, 07:51 PM
Pure5.0
Pure5.0's Avatar
Default RE: problem
The computer will recalculate the proper parameters once you floor it at WOT. Driving it 5 miles or 50 miles won't make a difference.
My car does the same thing. When it is cold and I have driven it hard (late for work kind of driving) and when I press in the clutch it drops to 500rpms and back to 800-900 for normal idle. Only does this when I drive hard when cold. Shows that you should always warm up your car.
I also need an oil change really bad and have taken my silencer off too. But to let you know my car did that before the silencer was taken off. Think it is a bad battery or fuel pump showing signs of dying.
Pure5.0 is offline
69Volunteer
09-30-2015 10:39 AM
marc954
09-29-2015 03:05 PM
marc954
09-25-2015 06:48 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: problem
