Systemax2 kit-NOT FOR STREET USE?
RE: Systemax2 kit-NOT FOR STREET USE?
I was further interested and read up a bit so thought to share:
There are three basic levels of in-use emissions requirements that vehicle owners have to meet: (Memo 1A, Federal & California)
Memo 1A. This refers to a U.S. Environmental Protection Agency (EPA) memorandum that says it's illegal to remove, disconnect or disable a required emissions control device on any pollution controlled motor vehicle (PCMV), pretty much any 1968 (1966 in California) or later model year car/light duty vehicle used on public roads. What this means is that even if you don't have a local emissions-testing requirement, technically you can still break federal law by chucking/disabling your vehicle's smog equipment.
Federal Emissions Requirements. If your area has emissions testing, almost certainly some form of underhood inspection goes along with it. Technicians will check to make sure that all required smog equipment is installed and functioning properly. This does not mean you can't change things! You just have to make sure changes you make are smog legal and comply with Memo 1A. Because you may need to prove compliance to an inspector, most product manufacturers offer documentation that states their products are at least "49-state smog legal," effectively claiming that their products satisfy the EPA requirements. One warning: Products that claim 49-state smog legality are not legal for use in California (or states that use California emissions standards) on PCMVs.
California (CARB) Emissions Requirements. If you live in California or states that use California emissions standards, then Memo 1A/49-state smog legal isn't enough.
Your product must have an Executive Order (EO) number issued by the California Air Resources Board to be legal for use on a PCMV, unless it can be considered a replacement part. That means the manufacturer of the product must obtain an EO number before the product can be advertised or sold in California. The manufacturer must also provide an underhood label with the part that inspectors can use to verify that it's appropriate for the vehicle it's on.
Products that have EOs are often called "50-state smog legal" because having an EO satisfies both California and EPA requirements. This is pretty cut and dried except for some products like intake manifolds, which can qualify as replacement parts even though they're made by aftermarket companies. In these cases, many aftermarket companies include documentation explaining the status of these parts.
In the United States, emissions standards are managed by the Environmental Protection Agency (EPA). The state of California has special dispensation to promulgate more stringent vehicle emissions standards, and other states may choose to follow either the national or California standards.
The California Air Resources Board, also known as (CARB) is the "clean air agency" in the government of California. Established in 1967 in the Mulford-Carrell Act, combining the Bureau of Air Sanitation and the Motor Vehicle Pollution Control Board, the ARB is a department within the cabinet-level California Environmental Protection Agency.
One last bit:
Below taken from: 2008 Current Handbook of Registration Procedures
DMV CA GOV
21.070 Smog Certification Required (VC §4000.1)
A smog certificate is required for the following transactions for 1976 and newer
vehicles:
• A new vehicle not sold by a licensed California dealer and reported on an
Application for Registration of a New Vehicle (REG 397).
• Upon initial registration of a non-resident vehicle in California.
• A transfer application for a vehicle previously registered in California when the
vehicle is more than four model years old.
• A registration renewal for a vehicle that is more than six model-years old and is
located in a area subject to the biennial smog certification program.
Exceptions—A smog certification is not required for:
• Original, transfer, or renewal of 1975 and older year model motor vehicles.
• Original registration of a new motor vehicle sold by a California-licensed dealer.
The dealer must complete the certification portion on the California Application
for Registration of New Vehicle (REG 397).
• Original registration of a new direct import vehicle submitted with the ARB
“NON-USA Vehicle” certification.
DMV CA GOV
vehicles:
mungodrums
09-28-2015 10:54 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
mungodrums
Suspension
09-24-2015 10:12 PM
09-16-2015 07:53 PM
