reverse lights
reverse lights
my cars reverse lights are stuck on when i turn the car on. Where is the reverse switch that makes the reverse lights go on, is it buy the transmission or something? I just took out the bulbs for now but i wannna fix it.
RE: reverse lights
your gonna have to work under the car. it will be on the drivers
side kind of hidden,just follow the wires.when you find it there will be
a rubber cover over the switch pull it off "gently". the switch will
have a two-pronged screw type connectors on it. you know what
you might be able to take it off from there,depending on the angle
or you might have to drop the tranny!!!
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
