Stalls Out
Stalls Out
Hey all.. My power break booster had been bad for a while, and I was driving around with no brakes. Finally I decided I would fix it and put in a new break booster. So my brother and I did it, and now when I start the car, it idles real low at like 600 RPM, and when I am driving say I am coming to a red light, and I press in the clutch, it will die..
I have a BBK CAI, stock MAF, BBK 70MM TB, Trick Flow Intake, 1.7 Roller rockers... I am thinking the only reason it ran before is because the vacuum leak from the bad break booster kept the idle up.. and now that It is fixed, it idles too low, and dies on deceleration. Could the problem be my MAF??
I already checked the TPS and it is set to .98 on the dot. I also just had all the vacuum lines ran with new line (instead of the crappy plastic line).. So I don't know what else it could be.. Sorry this is so long, but I have never had a problem with my car until now.. Please help..
Thanks- Joe
Thanks- Joe
RE: Stalls Out
ORIGINAL: 91hatchgt
on my bbk TB there is no head on the stop screw, it is just a 'stud' I guess you could say, how do I adjust it without ruining the threads on the screw?
RE: Stalls Out
I would recommend you remove and clean out the IAC mounted on the throttle body as this is what is supposed to control the idle speed if everything else is working right. use some carb cleaner on it to remove any carbon build-up inside it. this thing works in combination with a small hole drilled in the throttle plate to let in enough air to control the engine speed at idle and on deceleration. if you do use the throttle stop screw to increase the idle speed you will need to reset the TPS voltage also.
RE: Stalls Out
ORIGINAL: roundman
I checked my TPS again and it was at 1.15 .. I dropped it back down to .98 and unpluged the battery for like 10 minutes.. It seems to have helped a lot as it no longer stalls, but the RPM's still fall terribly low on deceleration when not applying any gas. I was wondering if I need to adjust my fuel pressure, or my MAF is just holding back too much air..
Yes your MAF should be as big or bigger than your TB, I just haven't gotten around to buying a new one seeing how I just purchased a 2005 Yamaha YZ250 that I now have to pay for.. LOL . Do you think it could be the MAF at all Roundy?
trashxtrash
09-20-2015 10:49 PM
