351 build/hp
351 build/hp
hey guys wat do you think about this....357 stock bottom with forged pistons. 205 heads systemax II intake water to air intercooler, meth injection and a novi 2k with about 15-20lbs of boost. wondering what kind of power this would make...i saw a build where they used a 350 stroker with no meth or intercooler and got 800hp out of it...im looking for like 600..could i do it with this?
RE: 351 build/hp
Novi2k's are great sc'rs on stang as well as the Procharger kits... With a stroker kit- like Sultan68 said unless it's forged, some good pistons (dish preferably) 4340 crank... Yeah you can carnk the boost up in it... but at 12-15 lbs--- with a stock bottom end, and depending on howwell the heads are reworked, and all the non mechanical acc's.... I'd say you should be in the 650-700hp range... BTW what is the comp ratio?
At Boosted Performance where i had my car built in NC... They built a 408stroker w/ a vortech YSI-trim and it made a lill over 1k hp @ 24lbs of boost on pump gas.... It's all in what you build and how much $$$ you wanna spend.
Mustangs of Illinois
08-22-2015 10:00 PM
