Fuel Cell
RE: Fuel Cell
ORIGINAL: Dan89lx
I am gonna put a fuel cell in my car if i switch to carb. what kind of fuel cell are you guys running. i wanna mount it where the spare tire goes- what fuel cell will fit there.
I'm in the process of switching over to a carbureted engine and have installed the firewall and a 5 gal aluminum fuel cell. You can fit many different size fuel cells back in the spare tire well area, just depends on how big a one you want. Most all mail order places like Summit and Jegs give you the size dimensions so you can take the measurements and see what will fit in your case. The 5 gallon one I got is 12" x 12" x 8 inches with a 2"deep sump and fit just fine. You have to cut out a hole for the sump to fit through and the cell has four mounting tabs to bolt it down. You can get some models with a built in level sending unit if you want one also. Prices depend on material selected, aluminum or plastic, size, and options like level sending unit. You can fit a 10 gallon one back there also if the height is not too tall but that's about as large as you can go and still fit down in the spare tire well. If you want bigger, you can always cut out the bottom of the well and let a new cell hang down below the floor.
mrappe
09-26-2015 10:16 AM
