Some EEC test questions??
Old 05-04-2008, 12:49 PM
ryan_89_mustang
ryan_89_mustang's Avatar
Default Some EEC test questions??
Im going outside to selft test my car when I find out a few more things. My CEL doesn't work so I am going to use a analog volt meter. I am curious to what setting I have to put it on. The only settings in the DCV section on the meter are 500, 250, 10, 500u. Then theres DCA which has 10m and 250m. Can someone help me out please??
ryan_89_mustang is offline
Old 05-04-2008, 01:16 PM
94StinkinLincoln
94StinkinLincoln's Avatar
Default RE: Some EEC test questions??
analog has a needle, digital has "eletronic" numbers.
i would say 250, b/c 10 volts is less than the 12v -batt voltage, im not sure what voltages are seen during the test, but it would be an on to off then on kinda thing, a sweep up then pause then another sweep.
94StinkinLincoln is offline
Old 05-04-2008, 02:51 PM
ryan_89_mustang
I got code 82 secondary Air bypass circuit failure. Anyone know what this is??
Old 05-04-2008, 03:01 PM
ryan_89_mustang
I just did it with the engine running and got
21-Engine Coolant Temperature, ECT Sensor Out Of Self Test Range
33 - EGR Valve Opening Not Detected
91- o2 Sensor Circuit Indicates Lean -driver side
Anyone have any input theyd like to give
Old 05-04-2008, 04:27 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: ryan_89_mustang
remember to run a koer test engine must be up to operating temp or code 21 may be spit out so it may be a bogus code if you did the test on a motor still operating in open loop as for egr code is it deleted/ removed from car?? ecm automatically deletes function when probs occur or is removed and code 91?? make sure there are no exhaust leaks before sensor on that side and if not...make sure orange ground wire is secure on back of heads amd as long as the sensor reference voltage is there and ground is good.. try replacing that sensor and retest
mjr46 is offline
Old 05-04-2008, 04:31 PM
ryan_89_mustang
ORIGINAL: mjr46
remember to run a koer test engine must be up to operating temp or code 21 may be spit out so it may be a bogus code if you did the test on a motor still operating in open loop as for egr code is it deleted/ removed from car?? ecm automatically deletes function when probs occur or is removed and code 91?? make sure there are no exhaust leaks before sensor on that side and if not...make sure orange ground wire is secure on back of heads and as long as the sensor reference voltage is there and ground is good.. try replacing that sensor and retest
The voltage should be .5 volts correct? How do I check for this, also what wires do I use etc. thanks help greatly appreciated.
Old 05-04-2008, 04:35 PM
mjr46
mjr46's Avatar
yup ....use a digital multimeter and I don't have a diagram in front of me......but pm Joel5.0 he's got all this info off the top of his head
mjr46 is offline
1TUFF302
11-05-2015 04:02 PM
unit91
09-15-2015 09:53 AM
TfcCDR
09-14-2015 12:08 PM
uedlose
09-10-2015 03:30 PM
09-08-2015 11:50 AM
Quick Reply: Some EEC test questions??
