1500rpm bucking and starting up issues
RE: 1500rpm bucking and starting up issues
all the lines are new.
as far as putting it back the way it was, im going to do that but i havent had time to go out and put it back. my question was more geared towards...which one is correct?
Sorry, fell off a ladder yesterday and busted up my shoulder, if I recall from my setup the first example is the correct, the second with the PVC going back into the rear of the upper is not on mine, but again I have a stock setup.
just throw a stall converter in it if its a automatic easy fix!
if its 5-speed you sound like u have vaccum leak.. just get a standard manuel from any parts store and route the vaccum lines the way there suposed to be, i had this same issue and it turned out to be vaccum lines in wrong places with wrong psi of vaccum
wish i coulda help you more
still lookin for help on the first start up issue. it happened before i ever switch the vac lines and it still does it.
will not hold its idle until about 100* temp. otherwsie i have to hold the gas down or it dies
bump
update.... i put the vac tubes back to the way i had them and its wayyyyyyyyyyyy better. it at least runs by itself without dying but the idle is so crazy and sometimes i have to save it.
it drops down to 300rpm and then pops back up to 1200 then 500,1000,300, 1000,500,1200....
and so on. but again when she gets warm the issues stop completely. what the heck?
damn idle. i swear, i keep replacing things here and there, im only going to take it serious once i have the cash to redo my whole intake /fuel rails and injectors.
bump.
i just drove it to work and now just sputters when shes warm now, volts drop a bit and rpms go down to 600rpms and just jumps between 600 and 1k at stop lights.
whats going on here?
bryan616fl
01-25-2019 09:07 PM
