Timing advance problem
I've been having some power issues and hesitating problems with my '91. When I check the timing it stays the same with or without the spout connector. Also when I rev it up, the timing stays the same. Does anybody know what would cause the timing not to advance?
RE: Timing advance problem
Are there any codes? Timing is controlled by the computer with inputs from various sources. Start checking MAF sensor, TPS and the inputs to the computer. First, check for codes. Not all codes set the engine light.
KEM Motorworks
08-14-2015 10:13 PM
