Oil Weight
changin my oil this weekend
whats a good weight to put in there? i live in the texas panhandle so its never REALLY cold or REALLY hot just wonderin |
RE: Oil Weight
ive used 5w30 mobil1 full syn since day 1
RE: Oil Weight
What oil are you running now? And how's your pressure?
For a street car, you need a heavy enough oil to maintain proper oil pressure. That's all, no more. A heavier oil will create drag and cost you power. It will also wear out your pump drive parts a little sooner; especially the distributer gear. That's why so many new cars use 0W-20 oil. You also want to keep the spread fairly narrow. A 10W-50 is less stable over time than a 10W-30. Start with a good 10W-30 and see how it goes. |
RE: Oil Weight
i was thinking a 10w30 as well
whats the difference between that and a 5w30 |
RE: Oil Weight
It depends on how hot the engine runs as well. Viscosity is rated at a certain temperature, as oil temp increases viscosity decreases. That's why most race cars run heavier oils, and in hotter climates heavier oils provide more protection.
RE: Oil Weight
ok
so since its bout to be summer i ought to run heavier right? |
RE: Oil Weight
10w30, I live in texas also, never a problem..... oil related anyway ;)
RE: Oil Weight
most people run 10w30 in their cars..im running valvoline vr1 20w50 race oil
RE: Oil Weight
mobil 1 5w 30. full synthetic.
RE: Oil Weight
10W and 5W refer to cold pouring charectoristics. The W stands for Winter. A 5W oil will pour better at very cold temps than a 10W will.
To change the pour charectoristics, they have to engineer the oil with specific additives. The wider the spread, the more additives. With a regular dino oil, use the narrowest spread to meet your expected weather conditions. You would want to use a 10W-30. Synthetic are slightly differant. They can utilize a broader spread without concersn. So if you're using a semi-synthetic like Mobile 1, Penzoil, Quaker State, etc, a 5W-30 will be more than enough. |
