coolant sensors
coolant sensors
Hi guys,
I was wondering if anyone know how many coolant temp. sensors there are...
I'm replacing my radiator and thermostat and figured I would replace the sensors as well... I know there is the single wire sensor for the gauge and I thought there was only one more. But when I was looking I found one on the right side (to the right of the distributor) and one almost straight back from the gauge sensor... does anyone know what those other two sensors are? I mean which is which? I know one is the temp sensor for the ecu...
Thanks!
Thanks!
RE: coolant sensors
The single wire sensor on the front driver side is the temp sensor for the guage. The sensor directly behind it is the Air Charge Temp sensor (ACT).
On the passenger side front, the temp sensor for the ecu is in the hard coolant lines, right next to the fuel rail connections.
RE: coolant sensors
Air Charge Temp Sensor
Item#: MPETS5200SB
Coolant Temp Sensor for ECU
Item#: ECHTS4060
Coolant Temp Sensor for Guage
Item#: MPETS6628SB
These are all part #'s pulled from Napa's website
Item#: MPETS5200SB
Item#: ECHTS4060
Item#: MPETS6628SB
RE: coolant sensors
ORIGINAL: 93_five_oh
ok cool thanks!
are the ect and act sensors the same type? same part number that is.. the guys at napa can't help me. lol
ok cool thanks!
jwog666
12-27-2021 08:09 PM
