engine banging ...like midgets with hammers inside of valve covers
RE: installing pushrods NOIsE??
you need to stop guessing, take your old pushrods and measure them
if you do anything else that what I have stated above... you will deserve and ill effects and damage that you may cause to your engine.
basicly you can tell bye feel man if your experianced, also did you take a air gun and blow through the galley in the rod? make sure there clear? no factory defect in the craftsmanship of the rod? iv seen a rod blocked by metal when it was forged, also you need to pull your coil wire off and have someone in the car turning it over with the valve covers off and watch all the lifters and make sure they all look they moving correctly, its hard to screw up rods lol.. lenth is a issue, and can be off less then you can see by the eye man, need to messure them.
ORIGINAL: tucstang85
and why isnt it starting not that ive really tried
Gary Ugarek
63
12-11-2015 02:01 PM
waid302
09-14-2015 11:19 AM
YoungStangsMan
09-05-2015 07:01 PM
inyadreems
08-21-2015 09:10 AM
