top end install..
Old 05-12-2008, 08:59 PM
88_5.0
88_5.0's Avatar
Default top end install..
hey guys it's been a while since i've posted on here but here's my question. I've finally got some extra cash built up and I am interested in buying the trick flow top end kit. I was just wondering how difficult the install is. I've replaced the entire engine in my car but that was with a huge amount of help from my very mechanically inclined friend. I have done a clutch swap myself, not that has anything to do with a top end, but do you think since i was able to do that no problem, could I do the top end myself? any replies are appreciated and info on the kit would be helpful too. thanks
88_5.0 is offline
Old 05-12-2008, 09:29 PM
ColdCityMustang
ColdCityMustang's Avatar
Default RE: top end install..
Top ends aren't bad. Take your time and choose a systematic approach to it so nothing gets lost or broken. I've done two, not to bad. They're just nuts and bolts : )
ColdCityMustang is offline
Old 05-12-2008, 09:30 PM
crusin92red5.0
crusin92red5.0's Avatar
ya u shoul have no problem. i've never done it before and am in the middle of doing it right now. engines out, i painted the block today and i'll start putting it back together thurs,my next day off. i've taken it real slowcuz of school butnow that its over i'm ready. i bought the tf top end kit too. i figured its the easiest way to learn with all the parts handed to yousince i've never done it b4
crusin92red5.0 is offline
Old 05-12-2008, 09:46 PM
5spd GT
5spd GT's Avatar
Link
5spd GT is offline
Old 05-12-2008, 10:10 PM
88_5.0
88_5.0's Avatar
thanks for the imput guys
88_5.0 is offline
Old 05-12-2008, 10:21 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
for the price of a trick flow kit you could piece together a better set up that'll yield more power
mjr46 is offline
Old 05-12-2008, 10:23 PM
88_5.0
88_5.0's Avatar
ORIGINAL: mjr46
any suggestions on combo's then?
88_5.0 is offline
Old 05-12-2008, 11:03 PM
highspeed
highspeed's Avatar
Be careful not go to excesive with the cam lift... you don't want to damage your new Heads or Valves with piston and valve clearance issues.
highspeed is offline
Old 05-12-2008, 11:09 PM
94StinkinLincoln
94StinkinLincoln's Avatar
depends on what your ET goal is... stroke or no stroke, im guessing no stroke this go around...
there are many heads out there, Edelbrock, AFR, Canfield, TF, then your ford iron heads (gt40)
AFR 165 is probally the smallest size head except for the edelbrock performer (not rpm) 1.9 intake valve.
then you have AFR 185, 205
edlebrock rpm, victor jr's
canfield 170 i think it is and the 195 then bigger
TF wedge, hi ports,
each company has small and large heads, if you dont plan to spin real high (<6500) you wont need huge heads for a 302.
cam selection is the big factor...save yourself the trouble...custom cam ftw
edelbrock, holly, or TF make good intakes
94StinkinLincoln is offline
Old 05-13-2008, 07:43 AM
CantStopTheFox...
CantStopTheFox...'s Avatar
I used a Haynes manual, these directions:
http://www.allfordmustangs.com/techa...intakeswap.pdf
...and the MustangForums of course
Good Luck!!
CantStopTheFox... is offline
Quick Reply: top end install..
