Fuel Filter?
RE: Fuel Filter?
I can tell you that every fuel filter I've ever seen has an arrow on it to indicate which way it should be put on. I've never put one on backward, so I don't know. Get under the car and look for the arrow.
RE: Fuel Filter?
ORIGINAL: 94GTPRO5.0
Can anyone tell me if a fuel filter on backwards will cause the fuel to not flow right and/or cause a car not to idle or even run like should? [sm=headbang.gif]
RE: Fuel Filter?
To answer your original question, Yes a 5.0 will run with the fuelfilter installed backwards just fine. But the filter will not filter worth a darn., meaning you coulad be getting all sorts of junk from the tank up into the lines and so on. If theres any doubt you better check it .
mrappe
09-26-2015 10:16 AM
