289head on 302block
289head on 302block
i just heard about a guy near me running a 289 head on his 302, cam, intake, other minor bolt ons and dynoing N/A at 290hp.
i guess it works really well doing this because of the small combustion chamber upping the compression. can you still run nitrous on high compression? anyone experiance or know anyone running this set up or have any input on it?? im just curious of the efficiency of it.
RE: 289head on 302block
Haven't calculated CR, but after 16 yrs. of use/abuse, it still pumps 200-205 psi in a cylinder compression test. One little detail you have to check/look out for, is the match-up of the head-to-EFI intake coolant ports........ 289 ports are smaller, in my case I have a carburetor, so no problem there. Another detail is the possible problem installing the corner HR lifters with the heads installed...... Best 289 heads?..... HiPo style with small chamber, guide plates, adjustable roller studs.
In my case..... I wouldn't spend $$ in GT40/GT40p heads over the 289 heads I have........ Next logical step for me are some Canfiled 195's or TFS..... and obviously, the X-303 would go.
It will depend on the budget and goals...... options?:
- GT40's
- Ported E7's from Thumper of Orange Park
- Canfield, TFS, RHS, AFR, etc
- GT40's
