smog pump bypass
Old 04-24-2005, 10:59 PM
black89gt
black89gt's Avatar
Default smog pump bypass
i did the smog pump bypass and i got the right size shorter belt. It was a 77inch belt and it fit but it was tight. and after a few days, i checked the belt again and that damn thing stretched out and the part of the belt from the water pump and hte a/c were rubbing so i had to change back to the stock belt. Does anyone know where i can get the smog pump replacment pulley and stuff? cause i dont wannag o through all taht trouble again. thanks please reply fast! thanks
black89gt is offline
Old 04-24-2005, 11:20 PM
stanglx2002
stanglx2002's Avatar
Default RE: smog pump bypass
the belt you need is a 850K6 is the part number
stanglx2002 is offline
Old 04-24-2005, 11:23 PM
primetime5.0
primetime5.0's Avatar
if it stretced then buy an even smaller belt
primetime5.0 is offline
Old 04-24-2005, 11:41 PM
sastangman
sastangman's Avatar
i have a 77 inch belt on my car and haven't had that problem,are you
sure you tightened down the alt bolts or something?
sastangman is offline
Old 04-24-2005, 11:44 PM
stanglx2002
do you have the belt routed right
Old 04-25-2005, 12:04 AM
jpc
jpc's Avatar
I had the same problem when I deleted my A/C and bypassed my smog pump, had two different belts stretched out the tensioner to max that I thought was the right size, third one ended up with the tensioner arrow right in the middle that was three years ago and never stretched anymore, so like Mustang30240 said get one even smaller..
jpc is offline
Old 04-25-2005, 01:10 AM
dc_mann8
dc_mann8's Avatar
u probably routed it the bad way is u used 77, mine needed 83.5
dc_mann8 is offline
Old 04-25-2005, 02:36 PM
92hatchLX
92hatchLX's Avatar
What is the correct way to route it, I have belt number 850K6 and someone gave me a diagram and it absolutely will not fit. StangLX can you show me the way that you routed it with that belt?
92hatchLX is offline
Old 04-25-2005, 02:45 PM
stanglx2002
https://mustangforums.com/upfiles/91...EFA38AE818.gif
this is how i routed mine
Old 04-28-2005, 09:30 PM
hawaii5.0
hawaii5.0's Avatar
835k6. is the part number 83.5 inch belt
hawaii5.0 is offline
Quick Reply: smog pump bypass
