Engine Help?? somewhat overheating
Old 05-16-2008, 08:24 PM
ChevelleStang
ChevelleStang's Avatar
Default Engine Help?? somewhat overheating
Can anyone help me figure out why my car is doing this. Randomly the temperature will rise on the car. and then it will drop back to normal. I have a code reader and it seems to be throwing the coolant temperature sensor. Do you think this could be the reason for the temp fluctuation of the guage in the car. Do you think my engine is over heating??
Thanks
ChevelleStang is offline
Old 05-16-2008, 11:59 PM
silentvoice19
silentvoice19's Avatar
Default RE: Engine Help?? somewhat overheating
my car does the same thing i thought it was the thermostat opening up
silentvoice19 is offline
Old 05-17-2008, 11:07 AM
wrenchturner75
wrenchturner75's Avatar
sometimes when the cooling system gets low itll develop an air pocket, this will cause a rapid climb in temp followed by a drastic drop in temp. with the car cold remove the rad cap, start it and let it run to operating temp you should see the water in the radiator drop some when the thermostate opens. let it do this several times before reinstalling the cap. if the cooling system was low you need to find out why because itll happen again, and be sure your overflow bottle is at the correct level. some guys call this procedure "burping the cooling system" and must be done anytime cooling system work is performed. and by the way it can cause a temp sensor code to occur. dont be fooled by just taking the cap off and seeing a full radiator, it can still have an air pocket. good luck.
wrenchturner75 is offline
Old 05-17-2008, 11:48 AM
bikeboy587
bikeboy587's Avatar
try replacing the radiator cap. i had the same problem on my 302 bronco and a new cap solved the problem
bikeboy587 is offline
Nick Oliver
10-17-2018 04:22 AM
yourmom6990
09-14-2015 10:52 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Engine Help?? somewhat overheating
