Mi caro no starto...help!
Old 05-17-2008, 11:17 AM
Does Not Exist
Does Not Exist's Avatar
Default Mi caro no starto...help!
Trusty 5.0 section, I need your help!
So I washed my car the other day, started it up pulled out of the bay everything was fine. Pulled up to the vacuums and decided to plug my phone in cause I had just found my car charger. I plugged it into the cigarette lighter that is down by the ashtray/foglight switch area...I never use this plug cause I dropped a penny in it a while back and it sparked and went crazy so I thought I'd leave it alone. Well I plugged the phone in and everything was going fine until I tried to start it. I turned the key to the "ON" position and the volts went up just like normal, radio turned on, etc...turned the key to start it and the volts completely dropped off, a couple lights went crazy and it wouldn't turn over or anything...completely dead. I can still turn the key to the "ON" position and things are OK (stereo turns on, volts go up, can turn the lights on, etc.) but as soon as I try to start the car it starts going nuts and doing what it did at first.
My car was A-OK until I plugged in that damn phone charger...I hate that thing...even if it isn't what caused it in the end.[:@]
Does Not Exist is offline
Old 05-17-2008, 12:44 PM
Does Not Exist
Default RE: Mi caro no starto...help!
Hmmmmm...after digging through a bunch of old threads it looks like it could possibly be somethin with the starter.
It'll click once then everything goes to crap....
Got a super sleuth on the case here.[8D]
Old 05-17-2008, 02:36 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
bad ground check them out on the negative side and for missing grounds off of the motor
rmodel65 is offline
Old 05-17-2008, 02:48 PM
haromaster87
haromaster87's Avatar
^^^Yes, the grounds love to eff up, lol. Mine almost caused my car to cacth fire. lol Also, have you checked the basics? I.e. dead battery, attempt a jump?
haromaster87 is offline
Old 05-17-2008, 03:45 PM
Does Not Exist
Yeah, the battery is fine.
I'm waiting for my roommate to get home so he can help...I'm pretty damn clueless when it comes to electric issues.[>:][&o]
Thanks, btw.
Old 05-17-2008, 06:32 PM
Shelty
Shelty's Avatar
could your starter just have seized?
my old car did that a few times on me... ate 3 starters in 2 years...
Shelty is offline
Old 05-17-2008, 08:10 PM
Does Not Exist
Just got her running. It ended up being the starter solenoid.[sm=smiley16.gif]
Atouk
08-04-2014 10:49 AM
Sxynerd
Mid West
04-14-2008 08:19 PM
Zoie_daGT
06-08-2007 03:02 AM
Quick Reply: Mi caro no starto...help!
