injectors leaking!!!
Has anyone used the pencil type 60lb. Siemens deka injectors on a fox body? I recently installed a set on my 347 blown 88 GT and the injectors are leaking causing the car to load up and not start back up right after shut off. Also the oil is starting to smell like gas which is probly from the gas leaking past the rings after sitting for a long time. Anyways, I know the make a direct fit 60 lb. injector that has the fat body style like the other ford injectors, just wondering if anyone has heard of these "skinny" siemens deka injectors leaking becase they are thinner that the stock injector. Thanks in advance.
