torque box reinforcement
Old 05-18-2008, 02:55 PM
kalash
kalash's Avatar
Default torque box reinforcement
i noticed the other day when i was installing my clutch that i had a crack in one of my lower torque boxes so i ordered the jegs torque box plates to reinforce them. i noticed that the lower control arms and springs have to be removed. why cant i just weld the plates on to the boxes with the lower control arms attached to the car?
kalash is offline
Old 05-18-2008, 03:22 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: torque box reinforcement
I didn't have to remove anything to install the lowers.
PRO50SC is offline
Old 05-18-2008, 03:26 PM
kalash
kalash's Avatar
i was wondering why the instructions would say that you need to, it seems kind of odd to do alot of work for nothing. did any body follow the instructions or does every body weld them on with the lowers attached
kalash is offline
Old 05-18-2008, 04:22 PM
kalash
kalash's Avatar
these are the plates that im talking about, ive got to do it monday so i just want to make sure that i can weld these on with out removing the lower control arms or should i stick with the instructions and remove the springs and control arms? also, if i weld these in place will i be able to install a battle box at a later date?
kalash is offline
Old 05-18-2008, 07:17 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Oh that explains it. I used the upr ones
https://mustangforums.com/m_2819477/...tm.htm#2819477
PRO50SC is offline
Old 05-18-2008, 09:16 PM
kalash
kalash's Avatar
so, any idea if i can weld these in place with out removing any parts?
kalash is offline
Old 05-19-2008, 01:14 PM
bighungrymatt
bighungrymatt's Avatar
no idea, if the directions say to remove them then you probably have too...
bighungrymatt is offline
Old 05-19-2008, 03:18 PM
Hamutoff
Hamutoff's Avatar
you dont have to remove anything - well I did not and I just welded the type you are talking about along with the thpe PRO50SC is talking about along with massive subframe connectors and I had the full suspension bolted in and torqued to spec while all welding occured
http://www.thatmetalbox.com/automoti...angBlanchWeld/
Hamutoff is offline
Old 05-19-2008, 03:20 PM
Hamutoff
Hamutoff's Avatar
Hamutoff is offline
Old 05-19-2008, 03:22 PM
Hamutoff
Hamutoff's Avatar
newest pic done 5-18-08
Battle boxes and torque box plates and full length subframe connectors with welded seat plates, none needed suspension removal, the battle boxes simply needed a bolt taken out and immediately placed back in. The way I have done it you would install the subframe connectors last, I wanted to see how it would work to install them on top (or underneath as it were) the torque box plates... since the sub frame connectors themselves had a built-in half plate... worked out beautifully I must say. Best of all
Hamutoff is offline
Quick Reply: torque box reinforcement
