Stock Rockers
Stock Rockers
The stock ratio for H.O.'s are 1.6 correct?? Does anyone know if the crown vics, 5.0 thunderbirds, Lincolns and any other 5.0 of the time frame have 1.6's or are they 1.5's? I am just trying to see if I might be able to find a cheap set of 1.6's from the junkyard. I know I would be better off buying a set of roller rockers but that can't happen on my limited budget at the moment.
RE: Stock Rockers
Yea I know they do. Hell with the cam that is in my motor I need 1.7's just to reach/exceed the stock lift of a H.O. cam. It is the cam that came in the motor when I bought it. I just found out my lift specs last night. Don't have a clue on the rest of the specs or the brand.
I .381
E .412
with 1.5's I have now. I just wanted something cheap to make my car run better than what I have now with junkyard parts until I install my other heads and get a new cam.
I .381
E .412
RE: Stock Rockers
I couldn't tell you why it has 1.5's on it. Thats how the motor came when I got my hands on it. It has a low lift cam, low compression 1978 heads, 1.5 rockers, and its a non roller 306 block. It came out of a bronco that was used to go mudding. I am suprised that it runs as well as it does for what it is. It may not seem like much but I kept up with a friends Lightning a couple of weeks ago on a rolling start from 15 to about 80 till a hill came along then I got over so traffic wouldn't surprise me.
BUT when I throw on my ported GT40 heads and a Eddy performer plus cam to go with my intake and carb it will be a beast in my stripped hatch.
RE: Stock Rockers
Well, if you want to be exact some of them probably are not even that with the flex that happens in the stock setup but still stock 1.6's are better than the 1.5's I have now.
69MustangCoupe393cid
10-03-2015 10:33 AM
JDWalton
09-24-2015 08:47 PM
