breaking up around 5200rpms
RE: breaking up around 5200rpms
i have 1.7 on my car and i have no problem with hittin 5500 i do it very rarely. I have stock cam and springs. Id vote on either loosing spark or fuel.I also have the same problem when my alternator was goin it would hit 5k and spit and sputter and not go any higher.
my dad explained to me at wide open throttle you need more fuel so i have to bump the pressure up anyways ( im running lean)...i never bring the car up past like 3500 because i try to be nice to it and not race around like an idiot...( they take your car from you over here )
well i have a 302 bored ,40 over to 308 edelbrock performer heads ( 1.90I, 1.60E with a competition valve job and porting/polsihing done by HBR Performance a.k.a heads by rick) b-303 cam, scorpion 1.6 rockers, mac 1 5/8 shortys- 2 1/2 o/r h pipe- 40 series flows, 373's, ram hd clutch, pulleys, mac cold air kit, cobra intake ( lower extrude honed), 65mm tb, 24 pound injectors, 190lph pump, mallory regulator, 4 core radiator,msd 6a box, a9l ecu, 94-95 73mm cobra Mass Air Meter,
ORIGINAL: mjr46
as long as he used the reccommended springs for cam and are set up correctly.. you'd think that may not be the prob...but anything is possible if coil bind occured and broke a spring
ORIGINAL: PJC Racing
My vote is for valve float.
