Scored at the junkyard
So I went to the local boneyard last week and I found some GT40 heads on an explorer for $20. I pulled the heads and took them straight to the machine shop where a buddy of mine works/owns. I am going to have them magnafluxed, cleaned, valvejob, shaved and if possible do a little porting and polishing on them. I am going to be running a comp cams 35-302-8 cam and scorpion 1.6 RR. Now for the questions.
1) what is the Stock e7 combustion chamber in cc's?
2) what is the stock gt40 (f3xx casting) combustion chamber in cc's?
3) with the specs listed below on the cam will I have any clearance issues also using the roller rockers?
Specs for the cam:
Part Number:
CCA-35-302-8
CamStyle:
Hydraulic roller tappet
BasicOperatingRPMRange:
2,000-5,500
IntakeDurationat050inchLift:
220
ExhaustDurationat050inchLift:
224
220 int./224 exh.
AdvertisedIntakeDuration:
281
AdvertisedExhaustDuration:
284
AdvertisedDuration:
281 int./284 exh.
IntakeValveLiftwithFactoryRockerArmRatio:
0.512 in.
ExhaustValveLiftwithFactoryRockerArmRatio:
0.533 in.
0.512 int./0.533 exh. lift
LobeSeparation(degrees):
112
Specs for the cam:
Part Number:
CCA-35-302-8
CamStyle:
2,000-5,500
220
224
220 int./224 exh.
281
284
AdvertisedDuration:
281 int./284 exh.
0.512 in.
0.533 in.
112
RE: Scored at the junkyard
[quote]ORIGINAL: ahittz24
63-64cc
65-67cc
you are going to have to check PTV clearance.... I don't think you will have a problem... but do you really wanna bet your heads on a guess??
ORIGINAL: ahittz24
ORIGINAL: ahittz24
ORIGINAL: ahittz24
