Can I reuse my head bolts?
RE: Can I reuse my head bolts?
As long as they're not damaged, use them!. It's always a good idea to clean up the threads on the bolts, and chase the threads in the block with the correct size tap. This will get you moreget accurate torque readings.
Thanks for the responses guys. I would hate to have to spend 60 bux on new ones when these are perfectly fine. QUICK QUESTION...... the air tube that goes on the heads... Im taking it off. What size bolts would I use to block off the hole on the back of each head? Thanks again!
Plugging Smog Hole ([/b]thermactor plug) they're 5/8-11 IIRC.
Trick flow sells them as TFS-51400265 or spark plug works also. [/i]
http://store.summitracing.com/partdetail.asp?autofilter=1&part=TFS%2D5140026 5&N=700+0&autoview=sku
ORIGINAL: ALMOST STOCK
can't remember what year it started but there were torque to yield bolts on foxes in later years and unless you had a stretch gauge to measure stretch..in theroy you are suppose to replace them per factory reccommendation but if yours is an earlier foxes you should be fine
