I just finished the install of a new water pump on my 95 5.0 and installed a new belt as well. I am posting to make sure the tension on my belt it correct. Should I be able to slide the belt off the idle pullie with a little force? I am not used to the auto tension and am just not sure if it is right. Any input would help.
No you shouldnt. A quick way to check is to find the longest length of the belt and push and pull on it. You should have less than 1 inch of deflection.
