Should I buy this engine?
I found this engine for sale for $5,200. I dont know how many miles/passes it has, but do you think its worth the price?
Boss 289 Block bored 30 over
Ford racing custom 4 bolt main caps
Canton oil pan
Eagle forged steel rotating assembly 331
Eagle Esp rods
JE pistons
Windsor Jr heads staged 3 ported all manly valve train flowed over 300cfm
Custom 351 head bolts
O ringed block
Bullet custom grind camshaft
Harden pushrods
Comp gold series 1.7 roller rockers
Headman wide bolt pattern long tube ceramic coated headers with scavenger collectors
Iske adjustable pushrod guide plates
Tall Aluminum valve covers engraved
Flow cooler waterpump
motor blueprinted and balanced 0 in the front 28 in the rear
Ford racing steel flywheel
SFI 0 balanced harmonic balancer
Edelbrock performer rpm upper and lower intake ported and pollished to the motor
complete c&l mass air meter
24 lb injectors
Msd billet distributor
kurban adjustable fuel pressure regulator
Canton oil pan
Eagle Esp rods
JE pistons
O ringed block
Harden pushrods
24 lb injectors
HIS S-197
08-10-2015 05:47 PM
