aluminum heads, cooling/waterpump
hey guys i just got my set of victor jr heads and i was talking to someone who did a lot of racing and building back in the day and he said aluminum heads are bad for street use b.c they heat up to quick nd warp and stuff. im wondering if you guys have this problem or if he is overexaggerating or what. i was looking into the water pumps that flow 50% more then stock, do those cause leaking probs at high rpms b.c of the volume of water they are moving? and what about the water wetter stuff. i originally bought it for my water to air intercooler but i was wondering if it would help the cooling process. thanks a lot
RE: aluminum heads, cooling/waterpump
think about this,most of fords cars from 2000's and newer have alum heads. they are fine until you overheat the motor, and thats when they warp, same goes for the alum blocks.
ORIGINAL: five0fm
ORIGINAL: five0fm
WetterWater works.
I've been using for about 12 years now and in the part of Arizona I live in I'd know.
I use it in my work truck, my DD and my racer.
It works with Aluminum too.
When using Aluminum heads on anything, always have 50% coolant/water mix.........
ORIGINAL: FASTBLACK
Prime example of an old school guy who refuse's to accept newer and bettertechnology.
ORIGINAL: five0fm
