long tube install... question
im installing my long tubes and o/r x pipe and im just getting started, i took off the strut tower brace, maf and the cold air intake, and the spark plug wires. i see that there is a tube that goes down into the passenger side header, number1 in the picture, how do i remove that? second question is how do i get the long pipe, number 2 in picture off, its loose and i can move it so that might be good enough, but just checking, thanks.
zoomed out
zoomed out
RE: long tube install... question
the pipe is for your egr, might have to lift up your intake to get it off. the rubber is your smog sytem, you should be able to detach it from the back of your smog pump and the back of your heads and your mid pipe
Luke9222
10-22-2015 11:55 PM
