Need to replace tie rod ends
Old 06-04-2008, 07:24 PM
imnotmy77stang
imnotmy77stang's Avatar
Default RE: Need to replace tie rod ends
i dont understand what is so hard about changing inners? i just did one on a suzuki swift today and it wasnt exactly hard. the inner tie rod end just threads onto the rack. unscrew it, and then crack the lock nut loose on the outer tie rod end and unscrew it. when you install the new one just screw it into the outer as far as the old one was (pretty easy to see since the locknut will still be on your old one, about 1/2 turn from being tight since all you had to do was crack it loose). because the pivot point is kinda stiff on the new one it took me a few minutes to get the threads lined up and started onto the rack. this would have been much easier had i popped out the outer tie rod end, but then again sometimes they dont wanna come out so that probably would have been a fight just the same.
really, its friggen EASY though. you could have them both changed in an hour and thats counting a cigarette and a cup of coffee. you can check to see if your other side is bad by jacking up that side of the car and trying to turn your wheel by hand. if it wiggles in and out see where its loose.
i love it when people automatically go spend all kinds of extra money
31.00 shipped from ebay for BOTH sides. these are probably off-brand parts and would probably end up getting sloppy after a few years, but they may last forever - ya never know.
rockauto.com has spicer and moog replacements ranging from 10.00 to 27.00 each, and autozone lists them for 17.00 to 28.00 each.
imnotmy77stang is offline
Old 06-04-2008, 07:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
inners are easy.. alot quicker than replacing rack!!! remove boot clamp then slide back then use and adjustable wrench and spin off inner after outer has been popped out of holder
mjr46 is offline
Old 06-04-2008, 10:40 PM
stang8689
stang8689's Avatar
I said replace the whole rack cause if the inners are shot it most likely has 100k+ and the rack as seen better days. It will save you work in the end. I paid $250 for the late model resto kit. It came with the rack, inner and outer tie rods, urethane bushings with sway bar end links and strut mounts
stang8689 is offline
Old 06-04-2008, 10:57 PM
302army187
302army187's Avatar
ORIGINAL: stang8689
link to that?
also, how much would it cost to have this installed?
i could use it despratly, my cars is bent pretty good, pulls a little to the right, and killed my "race"/ rim berring
302army187 is offline
Old 06-04-2008, 11:16 PM
302army187
302army187's Avatar
http://www.latemodelrestoration.com/...1&comp=LRS
theres the link, but whats the difference between "non-offset" and "offset" rack bushings?
Old 06-05-2008, 12:28 AM
88BlueGT
88BlueGT's Avatar
just do yourself a favor, if you buy the Flaming River kit, don't get the steering shaft. I have heard nothing but horrible things about them. I also bought the kit and ended up sending back the shaft and getting a flaming river shaft, much better design.
88BlueGT is offline
Old 06-05-2008, 01:17 AM
cheetha94607
cheetha94607's Avatar
well i ran into the same problem this weekend.the price for both inner tie rod cost the same for a rack with life time warrenty with both inner tie rods. just one question, witch rack to get 2.25,2.5, or 3 turn to lock rack
cheetha94607 is offline
Old 06-05-2008, 07:21 AM
imnotmy77stang
how could that possibly be the same price? your saying a whole rack only costs like 35-55 bucks?
wtf is wrong with you people?
and btw your car pulls because you needed an alignment, not because your rack is messed up. if its not leaking fluid its FINE
*sighs*
Old 06-05-2008, 07:29 AM
mjr46
mjr46's Avatar
ORIGINAL: stang8689
^^boy that's a rip!! I just put a rack in my 92 last saturday and cost me 79.79!!!
mjr46 is offline
Old 06-05-2008, 08:07 AM
bbbngowc
bbbngowc's Avatar
ORIGINAL: mjr46
ORIGINAL: stang8689
Were the parts used or you bought them separately? If New Pleasem by all means, send that link! I found them for $350, stang8680 got it for $250, you paid $79.79? I want the one you got.
bbbngowc is offline
Quick Reply: Need to replace tie rod ends
