Exhaust Issue
Exhaust Issue
Hey all, I have a strange problem I cannot see any exhaust out of the passenger tail pipe. I have 3 inch midpipes with no crossover and new mufflers. The tailpipes are however stock, This problem is so noticeable that I got into an argument trying to prove my car had dual exhaust. Anyone have a idea??
RE: Exhaust Issue
I don't think I can see any exhaust when temps are above 20celcius so I think I am fine. But when cold I see it out of the drivers only. Alot of the time there is some water dripping from the pipe aswell. I have no overheating issues and oil level has never increased.
RE: Exhaust Issue
ORIGINAL: 5.0stanger
Is there exhaust comming out?
You may have a problem with the side you can see...what does it look like?
RE: Exhaust Issue
It was like it when I bought the car I am assuming it would be correct because It seems like a prefessional install the pipes were bent by a shop for sure everything is welded from the hedders back. An exhaust leak just occured to me I am going to go check.
RE: Exhaust Issue
Bingo, I have A big leak after the pass muffler and a small one after the drivers muffler. It appears as if the weld has cracked but the tailpipes are original so it could be rust as well I suppose.
Galactic
04-29-2019 02:56 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
