stalling when coming to a stop
hey guys i have a 92 gt 5 speed, with a trickflow top end kit, 70mm throttle body, 24 pound injectors with matching mass air flow, also a 255 fuel pump. the car runs good an holds a idle at start up. when driving it drives fine, when coming to a stop and pushing the cultch in it just dies. i can prevent it from stalling if i give it gas. i adjusted the tps to .98v and i also adjusted the idle speed to try to correct the problem, please help me out thanks.
RE: stalling when coming to a stop
If you have a code 29 (= VSS sensor circuit) showing in a KOEO as a continuous memory code, it needs to be fixed. The VSS signal is used for idle control and prevent that same problem you're having. Run a DIY KOEO/KOER/Cylinder Balance Self-Test and LUK.
musnicki
09-23-2015 07:11 AM
