Electric Fan Install
RE: Electric Fan Install
You can use the alt from any 94-95 mustang gt.
Thanks for all the help guys. So for running the wires to the relay, do i just chop the connector off the end of the wiring harness? What do i do with all three wires just from the fan?
Keep the plug that goes into the fan and chop the other end off. Solder some wire to the end you cut and then shrink rap them and wire them according to where they go GROND/POWER ECT. You do know what wires are what right. If not i do.
ORIGINAL: droptop302
ORIGINAL: 1985stang
Wiring is definately not my strong suit. Black is ground, red is power, so what is the yellow wire for? Is that the wire you would run to control low/high speed?
11-10-2015 11:39 AM
09-03-2015 07:14 PM
