Spark Plug Question
RE: Spark Plug Question
The specs on the Autolight 3924's is as follows:
Heat Range Chart Location D11
Hex 5/8"
Reach 3/4"
Resistor/Non-Resistor/Suppressor Suppressor
Seat Gasket
Thread Diameter 14MM
Tip Power
While the Autolite 764's specs are
Heat Range Chart Location D15
Hex 5/8"
Reach .708"
Seat Tapered
Tip Power
So as you can see, the major differences are the seat style, heat range, and a ever so slight (.042") difference in the reach.
Hex 5/8"
Reach 3/4"
Seat Gasket
Tip Power
Hex 5/8"
Reach .708"
Seat Tapered
Tip Power
ORIGINAL: 94StinkinLincoln
edelbrock rpms use stock plugs, which i believe is the 24's or 25's
