question about timing
First , I want to start by saying thank you to everybody who helped me out last month
I swapped my engine , now the engine is running and tonight my stang hit the road again
I have a little question about timing .... The engine I put on my car is a 5.0 .....pretty stock with a camshaft (B303)...well , this is what the guy told me ... mass air flow ... H pipe ... basic stuff like that
Should I change the timing from "10 degrees before top dead center" to another timing because I changed the cam? I set the timing to 10 degrees before top dead center and the engine works , but the idle is bad a little bit ...
Is it the standard setting or I should set the engine to another timing because I changed the camshaft?
thanks a lot again!!
Franck
Franck
RE: question about timing
ORIGINAL: franckybosnie
Thanks for the fast reply!
Ok so there is NO relation between camshaft and timing , am I right?
If I don't use 91 octane with 14 BTDC ... the engine will suck ?
Calizic
08-28-2015 01:46 PM
