gauge install
Old 04-28-2005, 11:38 PM
5.0sTheWayToGo
5.0sTheWayToGo's Avatar
Default gauge install
does anyone have any idea how to instal a electric water temp gauge? whats easyier to install a electic or a mechanical water temp. gauge? i look forward to doing this project this weekend. thanks for the help
5.0sTheWayToGo is offline
Old 04-28-2005, 11:41 PM
silver91gt
silver91gt's Avatar
Default RE: gauge install
I got one, the hard part is routing the lines through the firewall.
other than that just hook up both ends.
silver91gt is offline
Old 04-29-2005, 12:50 AM
5.0sTheWayToGo
yeah how to you like the gauge? was it farly easy to instal.. im 17 with a 94 gt and im hoping to get the electric water temp and the mechanical oil pressure gauge hooked up this weekend. do they make a mechanical water temp gauge? would that be easyier to work with?
Old 04-29-2005, 01:27 AM
wafrodon
wafrodon's Avatar
Don’t most people switch TO a mechanical water temp gauge for more accurate readings? Or is it for other reasons?
wafrodon is offline
Old 04-29-2005, 01:54 AM
86HOGT
86HOGT's Avatar
Right. You can't beat the accuracy of a liquid filled mechanical gauge.
86HOGT is offline
Old 04-29-2005, 02:46 AM
Dan89lx
Dan89lx's Avatar
the mechanical water gauge is easy too, just route the little metal wire from the gauge to the sending unit that screws into the intake. its simple.
Dan89lx is offline
Old 09-05-2009, 12:24 PM
Fox Body 5.0
Fox Body 5.0's Avatar
can anyone tell me where the wiring for the following electric gauges go ?
i just want to be sure i dont want to mess this up
water temp
volts
oil pressure
Fox Body 5.0 is offline
Old 09-05-2009, 12:44 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
What kind of gauges are they and didn't they come w/ instructions?
PRO50SC is offline
Old 09-07-2009, 02:40 PM
Fox Body 5.0
autometer cobalt series electirc gauges
water temp and volt gauges and no neither one them had instructions
i called autometer and its like talking to an infant
Old 09-07-2009, 06:21 PM
Ginzo
Ginzo's Avatar
temp gauge is very easy there is a red power wire that u can hook to a constant power to the fuse box and black is ground and then u neeed to run the wire threw the firewall by the clutch cable if u have a cable trannie. and then u hook up the sensor right on the manafold... i just hooked up mine..goood luck
Ginzo is offline
Quick Reply: gauge install
