belt rubbing
belt rubbing
i just put on ford racing ac eliminator don't have a smog pump i got a 73 inch belt stock pulleys i think, wasn't told they were under drive when i got the car. I'm running the belt like the pic on the bottom left of this link http://www.cjponyparts.com/NewTech50Belts.aspx my trouble is the belt tensioner is pushing the belt down on it's self, it's tight but rubbing will this work are is something wrong if so any ideas
RE: belt rubbing
im in the same boat.. kinda confused though cause it never rubbed on my other 5.0
i needed a prybar to get the belt on though.. and on this car i could do it by hand.. barely.
maybe tensioner has too much slack..
RE: belt rubbing
ORIGINAL: samsonhusky
well it hurt to run it like this
the belt is rubbing itself, right??
is it supposed to do that (no)
therefor.. should you drive it like that.... NO!
RE: belt rubbing
well got a smaller belt on with about 1&1/2 inch clearance someone told me to use a belt for a 92 lumina 3.1 710k6 prestone so it wouldn't strech as much as some of the others do. couldn't fine prestone here so went with napa # 060710 they said it was better that the gatorback belt and wouldn't strech much either. It was tough getting it on but seems to be working fine the guy that told me about this belt isn't having any trouble so hope this works out. mjr46 did you try a belt this small it's 71 inch and did you get that much clearance
autoedit
09-27-2015 06:37 PM
ccdguy
09-19-2015 05:20 PM
