Why cant I get any Engine Codes ?
I'm tryin to to do a KOER test and I cant get any codes. I located my eec test box and took off the cover. Put my volt meter pos. post on the pos. batt. terminal neg volt meter in the 4th terminal in the box and ran a jumper wire from the single wire connector to the 2nd terminal in the eec box like my book says too. I turn on my key and nothing, no jump in the meter at all. Is my volt meter the wrong one or am i doing something wrong ? my meter does ac,dc and amps. I might not have the correct volt meter, it is also for stuff around the house as well, not specifically for automotive.
RE: Why cant I get any Engine Codes ?
You can use a test light connected to the battery (+) terminal instead of the VOM. Check this DIY KOEO/KOER/Cylinder Balance Self-Test procedure for a little more info and LUK.
ORIGINAL: z24stang
What if you still cant get codes.Say the wrong single wire was hooked up? Is the computer screwed.
Well I tried the test light trick and still nothing. When i did the test light and turned the key forward the light just stayed lit up. No blinking at all. For some reason though i heard my fuel pump relay kick in and my pump ran for a few seconds. ?? I dont think my check engine light even works, weather its blown bulp or what, so there wasnt any engine light flashing. So what do u guys think i can do now to get some codes ? Or is it possible i do have a bad computer ?
And to Joel5.0 do you think if that SIGRTN circuit on the board has a blown line what do you do Replace The Computer ?
ORIGINAL: bjlo4life
ok guys finally got some codes. As for the KOEO i got 22-map sensor outa range
67-a/c clutch
81-thermactor air circuit
82-thermactor air circuit,integ. cont. crt
85-canister purge circuit
as for the C cont. mem. i got a 22-same as above
31-canister or egr valve control system
51-coolant temp sensor
53-throttle post. sensor
54-vane air flow sensor or air charge temp. sensor
63-throttle post. sensor or circuit
96-fuel pump circuit
Now i didnt get any codes for the R engine running for some reason. I tried it twice and still woulnt get any codes. Do you guys think i need to worry about any of these codes , if so what ones are really critical to fix. Thanks againg for everyone who has helped. especially w/ just getting the codes in the first place. good tip on grounding the sti terminal.
67-a/c clutch
