Instrument illumintaion?
I bought an 88 gt with the instrument lights not working. the idiot lights work, and so do the guages (execpt oil pressure) just not the illumination. this includes the heat *****...
I checked the fuse, and tried hitting the dash
Is this a common problem with these cars, any simple known fixes?
Thanks for all and any help...
RE: Instrument illumination?
The switch that turns on the interior lights also dims the dash lights and makes them bright. Its to the left and the bottom of the instrument cluster i think thats what you need to change.. It rolls to the left and to the right..
Oh that switch, hmm. good thinking
but i think that when i roll it untill it clicks it does turn on the dome light. if it does turn on the dome light does that mean that its good??? or could it still be bad? How hard is it to pull the cluster in an 88 gt?
Thanks guys..
Thanks guys..
i had something like this happen, when you push the h/l switch in do the parking lamps and everything come on? mine had a wire that came out of the connector and the tail lights parking lights and dash lights were all out. the h/l would come on but thats a different position that ONLY turns the h/l on everything else goes from the previous position. i had to drive home like that one night and i was just happy i didnt get pulled over
ORIGINAL: fordork
Thanks guys..
Thanks guys..
yes the parking lamps all work when the switch is in the middle position. i wish is was that simple. who knows what it is. ill probably just buy a small light and mount it facing on the front of the guages...
andrew1969
16
01-08-2016 02:48 PM
Matt's 95 Stang
10-05-2015 07:16 AM
