dropped fox
dropped fox
Is there any way to tell how much lower my car is than stock? I talked to the previous owner and he said he can't remember which springs he used. I'm trying to get it a little higher in the back to try to restore the geometry in the back for my control arms and to fit the larger drag radials. I was hoping maybe somebody would know the stock height of the wheel well in the back or anything like that.
RE: dropped fox
Go measure and tell us what yours is. I asked a similar question awhile back and someone told be stock is like 27 inches from ground to well or something close to that. I will see if I can find the thread. I would give you mine but its on stands right now.
RE: dropped fox
Here was my thread.
https://mustangforums.com/m_5074169/tm.htm
Toward the bottom someone gave me the stock specs I believe.
RE: dropped fox
Alright, well the top of the well measures 26 3/8ths, but this is with the 245/45R17 tire. The tire size is equilvalent to 25.7 inches and the stock tires are a half inch smaller so basically I have about a 1.25 inch drop. The only way I can see that I couyld get better geometry for my LCAs would be to get some stock springs or ones with like a .25-.5 inch drop.
