t-5 rebuild
t-5 rebuild
my trans will not go into 2nd gear if u shift any higher than 3000 rpm so i am guessing that a synco is out in 2nd whoi hard would it be to replace i want to rebiuld because i can not find i good trnas around me for less than 600 bucks used
RE: t-5 rebuild
i currently have a 1990 gt hatchback and im in the process of rebuilding my t-5. its not too bad there isnt too much for parts considering some of the other transmissions i've had apart... mine was poping out of second gear and needed a clutch. thats why i choose to rebuild it.
Derrick
Derrick
RE: t-5 rebuild
RE: t-5 rebuild
so what do u think bout this kit and what all special tools do i need
http://cgi.ebay.com/ebaymotors/MUSTA...spagenameZWDVW
RE: t-5 rebuild
Its about all i used. You just need some general sockets and wrenches, flat snap ring pliers, and a press or hammer/block of wood. Get some good RTV sealent too. I took pictures as I went so i would know the order it goes back together. If your bearing retainer is still the original aluminum you should change it to a steel one.
RE: t-5 rebuild
syncronizers are part of the gear hub!!! when cars grind going into gears like the 5.0 does on 2nd expecially people say rebuild it but you need to inspect the 2nd gear hub as tthe syncro teeth are built onto it and if they are mushroomed flat..you'll need to replace that gear all the rebuild kits come with are the blocker rings that mate to the syncro hub and slow the gear down from spinning to a grind free engagement can take place...alot of times the blocker ring friction material is worn off..causing grinds cause it no longer can slow gear down from spinning on output shaft
