rpm's wont go down
rpm's wont go down
like the title says, my rpm's do not drop when the clutch is pushed in.
if im off coasting, they go down. but say im slowing down for a red light, i downshift to 2nd and put it in 1st once im at a complete stop. the rpm's will hang at like 1500-ish
getting me unwanted attention
RE: rpm's wont go down
I had the same problem back in the day when i still had my 302. All I did was run a relay in the power wire to the IAC motor. Once the car was fully warmed up, I would just shut the IAC off and my RPM's wouldnt hang anymore. I'm not sure if it was a problem, or issue in my stock ECM, but the problem went away when I installed my megasquirt
there is a built in dashpot function in the ecm and is more so prevelant on sn-95's as it's built into the programming of the ecm..I had an article on it and it's purpose somewhere
Omgitsa88Stang
10-05-2015 07:33 AM
