breaking up at 2500rpm??
ok when im driving around in my 89gt i noticed it breaks up kinda like around 2500 rpm it feels like its breaking up or like popping..the cars fuel pressure is at 42 psi...anyone have any ideas..timing too advanced maybe
RE: breaking up at 2500rpm??
inspect ignition components..like cap, rotor , wires and or coil ;)
ORIGINAL: mjr46 inspect ignition components..like cap, rotor , wires and or coil ;) also check plug gap try gapping at .042" and see if it helps, and if you have platinums... ditch them for stock coppers. |
ok im running autolite 3924's gapped at 52 i belive ( edelbrock tech said) new msd cap,rotor and ford racing wires...kinda started outta no where...coil is like 1 month old also ( msd coil)
At night, a spray bottle with a dash of table salt, sprayed over the ignition components, like coil, and wires, will show ignition issues by you seing the sparks.
i checked at night and theres no arking or any spark visible... Could it be a bad dizzy?i just replaced my ecu and car ran mint and i noticed the breaking up today
ORIGINAL: 89mustangfive0 i checked at night and theres no arking or any spark visible... Could it be a bad dizzy?i just replaced my ecu and car ran mint and i noticed the breaking up today |
i tried cylinder balance test cant run cause i have 2 codes for my air injection system
clear the codes and try again if not then you'll need someone with a portable lab scope to look at ignition system patterns to narrow down miss..expecially when all parts are new;)
ok..i also noticed wiggled all the wiring that goes to the starter relay near the battery, like all the fuseable links and i noticed it hasnt broke up, is it possible i just have a wiring issue?
